Revit não exibe topografia primitiva
carolinarosa.arq
carolinarosa.arq
Pessoal,
Bom dia.
Eu havia criado uma topografia primitiva e a alterado em meu projeto utilizando a ferramenta superfície com eixos. O calculo na tabela de topografia ficou perfeito. Entretanto em um dado momento o revit parou de exibir a topografia existente nas vistas, já tentei alterar o filtro de fase várias vezes e ela não reaparece.
A tabela de topografia continua fazendo o calculo corretamente, o que significa que a superfície original continua ali.
Alguém teria alguma ideia de como solucionar?
Accepted solutions (3)
The Existing Toposurface - the one you created a Graded Region Copy of - is Demolished.  In order to see it in a later Phase of construction View, you need to change the View Phase Filter to one that will show Demolished or remove the Phase Filter entirely from the View (e.g. set it to Show None).
FWIW: if you are going forward with Phasing and preforming Cut/Fill calculations in each forward Phase, you need to establish a "new" existing toposurface condtion at the beginning of each of those Phases and create a  graded region copy from each new existing condition.   Get it?
carolinarosa.arq
Thank you,
I tried to change Phase Filter no "None", and every Phase Filter, and still don't see the existing toposurface:
When i change Phase Filter to "Demolished" i see nothing.
I am working with just two phases "existing" and "new"
RDAOU
@carolinarosa.arq
Show Complete???
BTW...in your schedule, the toposurface is for all created in New Construction...No existing topo will show in this one
Create a new schedule for Toposurface of the Existing Phase...if nothing shows there, then you do not have existing topography
Sounds like you deleted it then.  You are welcome to post your file if you want to.
carolinarosa.arq
In case that i deleted it, it would work if i copy the existing toposurface from my older file?
mauricio_mssf
Não encontrei no arquivo,
Você pode copiar de um arquivo anterior, copia e cola pela ferramenta de copiar no mesmo lugar.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
