Annotation size change
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
cadedu22
1899 Aufrufe, 4 Antworten
Hey,
Is there automated way to Change size of all annotations at once?
Like drawing is 1:100, but all Annotation sizes are 1:50.
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: cadedu22
@cadedu22
You will need to create a new type  and swap them...same for the grids
Nachricht 3 von 5
cadedu22
als Antwort auf: RDAOU
Gotcha, need to change everything manually.
Nachricht 4 von 5
syman2000
If you don't want to change the annotation, you can set the drawing as 1:50 and then print half-size print to get to 1:100. Most often this is how I achieve the half size annotation without doing too much work.
Nachricht 5 von 5
cadedu22
als Antwort auf: syman2000
Yeah, at start was thinking about same solution, i was hoping that there may be is such future already to avoid messing with printer.
