Revit material texture materials missing
My material texture images are missing in revit 2017. I went to common files(X86)-autodesk shared-materials-texture.. in that i cannot find any mats 1 2 3.. there are  UP1 LOW UP2 BASE UP3 MEDIUM.. what should i do?
hmunsell
are any of the materials in the Material Browser showing?
  • Manage ribbon > Settings panel > Materials
  • navigate to a material in the browser (for example... Brick, Common)
  • select the Appearance tab
  • pick the name under the material
that should take you tot he Mat folders where the materials are.
Howard Munsell
