Revit LT Beginner Help
JSCOTTDRAFTING
Message 1 of 8
JSCOTTDRAFTING
Hello and thank you in advance for the help and support.
I am purchasing Revit LT Suite as an upgrade to ACAD LT when my subscription is ready to renew. I am a 2 seat residential design firm in Florida. Can someone suggest a training manual for Revit LT that pertains to single family homes. I have attempted to use ADT, Softplan, Envisioneer in the past but keep going back to ACAD since that is my background. Since Revit LT uses ACAD drawing commands i think i might catch on this time. Any suggestions are accepted.
Thank you,
Jim Scott
J. Scott Drafting, Inc.
Replies (7)
Message 2 of 8
Sahay_R
I've used this to teach a Revit class. It does the job pretty well
https://www.amazon.com/Residential-Design-Using-Autodesk-Revit/dp/163057029X
Or
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 8
JGallagherP3A
Any of the Paul Aubin courses on Lynda.com would be perfect for you.
Lynda.com - Revit Tutorials
Stick with it and really try not to fall back to AutoCAD. Technology moves way to fast if you're stuck in the "can't teach an old dog new tricks" mentality.
Message 4 of 8
Viveka_CD
Hi @JSCOTTDRAFTING
I see that you are visiting as a new member. Warm Welcome to the Autodesk community!Smiley Happy
You can download beginner videos at the following resources:
  • Access resources as listed on our knowledge network page, that can help you learn how to use the software. Click HERE
  • Please check out videos related to Revit, available for download at the Autodesk design academy website
  • We have Starter Files, Software Tutorials, Instructor Manual and Design Thinking Videos available if you click on the asset download link for each video.
  • You can search classes available and you can download them from our Autodesk university website
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you,
Message 5 of 8
chrisplyler
Forget "Revit uses ACAD commands."
Maybe some of them DO overlap, but going in with that mentality is going to hinder you, not help you.
Message 6 of 8
I am not aware of any "Revit using AutoCAD commands". You should start fresh without any AutoCAD mentality in mind when you learn Revit.
P/s: ADT or ACA is at least running on AutoCAD interface and sharing basic commands. But you already gave up on it so...
Message 7 of 8
JSCOTTDRAFTING
After 14 Hours of Lynda.com instruction video's, I think I have a basic grasp on the software and feel confident I can implement
it within my company.
Thank you for the suggestion.
Message 8 of 8
Viveka_CD
Hi @JSCOTTDRAFTING
Just wanted to follow up and see if you were able to experiment with tools in Revit.
Let us know if you have additional questions and if you need assistance from the community!
