Tags with opaque masking regions are transparent in only one view......
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Sahay_R
1063 Aufrufe, 3 Antworten
This is what I see in the Project - the hatched area is a filled region and the tags are transparent
Here's what I see when I copy these objects (OK, the ones that Revit lets me copy) to a virgin project -
As you can see, tag #3 is opaque in the screenshot from the Test project - and also in all other sheets from the Project! The offending view has the same View Template and overrides (or lack thereof) as all the other views where the tags are working perfectly and doing what they were designed to do.
Some light in the darkness, please - nothing less. Chocolate and doughnuts will not do in this situation......
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Sahay_R
Is the view in wireframe visual style?
Nachricht 3 von 4
Sahay_R
als Antwort auf: ToanDN
(hides very very red face)
Rina Sahay
Nachricht 4 von 4
mmcintosh-ral
thank you for posting this.
very helpful to me today to see the answer.
