Revit LT 2024 Have Site Platforms Been Removed
8 REPLIES 8
Message 1 of 9
jamesWGU2T
445 Views, 8 Replies
I recently upgraded to 2024 from 2021 or 2.
So got a bit of a shock when I stared using the site topo. I found it very confusing and complicated to use. Can make it work, but seem to have to do things twice.
Have platforms been omitted? This was very helpful.
Is there a good tutorial to follow as the autodesk seemed to miss steps.
8 REPLIES 8
Message 2 of 9
in reply to: jamesWGU2T
No more Toposurface as of 2024. You could continue to use earlier versions of Revit to create your Toposurfaces, Building Pad, etc., and then upgrade them to 2024.  Food for thought.
Message 3 of 9
jamesWGU2T
in reply to: barthbradley
Good idea. Will use next time.
Message 4 of 9
jay_colcombe
These are 2 really good quick overviews
https://govdesignhub.com/2023/07/26/the-new-toposolid-feature-in-revit-2024-what-you-need-to-know/em...
https://revitpure.com/blog/toposolid
Jay Colcombe
Autodesk Certified Instructor
Message 5 of 9
jamesWGU2T
in reply to: jay_colcombe
Jay - thanks, very helpful.
Annoyed about the building pads though.
Please note the first like didn't work.
Message 6 of 9
jay_colcombe
Building Pads seems to be the breaking point for many on the crossover!!
Strange it works here
Jay Colcombe
Message 7 of 9
What didn't work?  Upgrading Toposurface/Building Pads to 2024?  Works for us.  What's happening on your end?
Message 8 of 9
jay_colcombe
Meant for original poster!
It’s a difficult one as there were also many negative views on the limitations of Toposurfaces!
The Toposolid work more inline with Revit and 3D element components and masses and probably more geared for future integrations with the ACC (Autodesk Construction Cloud)!
Possibly a more transitional approach could have been taken whereby it was rolled out along side the existing methods and then given release year to find the nuances and streamlining of processes so implementing would be less challenging could have been a loss less final!
But as previously mentioned there is always the option to stay in a previous version until all bugs have been fixed and sufficient resources are at hand to assist in the adoption of the new methodology.
Jay Colcombe
Message 9 of 9
jamesWGU2T
Jay - thanks.
Will just have to roll up sleeves and get into it.
Forma Design Contest
