Revit is giving me 'Intersecting Lines Error' when sketching
flora.grassi
Observer Observer
flora.grassi
Observer
Observer
I am attempting to draw a sidewalk to a main access ramp on a project, but revit keeps giving me the same Intersecting Lines message. I have tried a few different sketch configurations, but no dice. Ideally, the sidewalk wouldn't wrap around the ramp, but rather slightly blend into the shape, as it is represented below.Captura de tela 2023-07-07 071847.pngCaptura de tela 2023-07-07 071640.png
kostask_oionei
In edit mode in Revit you have to avoid intersections like below.
The linework must be a closed shape without gaps or intersections. The end of a line must be the start of the second.
Try to do two different objects.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
loboarch
Your closed loop sketch basically has a "short circuit". The line near the 13.1 running through the outer loop can't be there. That is causing the failure. I am not clear as to what you want to accomplish, but you have to do it with "closed loops".
Jeff Hanson
Principal Content Experience Designer
Revit Help |
