Revit In-Place Mass - showing up on all floor levels?
azhoq36UAA3
Message 1 of 9
azhoq36UAA3
Hi all,
Im very new to this platform, though i have been using Revit for about 3 years, im rather stuck with this in-place mass issue. I have created the below panel system around my main model via the in-place mass which goes up and returns over the roof of the building.
But the returns that go over the roof level are showing up on all floor plans/levels as shown below!
I have searched the forums but i have not managed to locate anything related to this issue.
What am i doing wrong? Can anyone advise. Any help appreciated!
Replies (8)
Message 2 of 9
Avaris.
That is because you modelled it as furniture. Furniture is an example of a non-cuttable family meaning that it is always shown as a projection. Normally you don't show cuts in your furniture so it makes sense.
To change that behaviour, make it a generic model (which is always a safe bet if you don't know how it should work).
Message 3 of 9
azhoq36UAA3
Oh no! Does that mean i have to remodel all of it?
Message 4 of 9
azhoq36UAA3
Sorry, ive just realised.  You are quite right Avaris. I havent used in-place mass at all! I used 'model in-place'.
What would be the best way to model this screen so that it cuts through at the various plan views
Message 5 of 9
Avaris.
It is a very unique component, so your choice to model it in place was correct. You only have to change the category to generic model and you are good to go.
Message 6 of 9
azhoq36UAA3
Thank you Avaris! I did think it was something to do with that.
Just spent the entire day creating this and have just finished off the other side. Should've stopped when i realised something was wrong.
Thanks again.
Much appreciated!
Message 7 of 9
azhoq36UAA3
Apologies for the constant questions...
So am i able to select what i have modelled thus far, and just change the category? Or must i redo it?
Message 8 of 9
Avaris.
You can just click the model in place > go into edit mode > change category.
The image in my first post shows it all.
Message 9 of 9
azhoq36UAA3
Got it! Works perfectly!
Thank you once again Avaris
