Hi Guys,
i am having trouble with the hatches in a dwg-file that I originally exported from Revit.
i created an acadiso.pat file that matches my revit-patterns and it seems to work well in autoCAD. The only problem is that the hatches in the exported file look completely wrong until i change the type from custom to predefined in AutoCAD. I dont need to do anything else - once I change the type, AutoCAD recognizes the right pattern automatically and corrects the problem. Is that so, that all hatches are first recognized as custom, even after i assigned the acadiso.pat file in the Revit Export Setup? Why do they look wrong in the first place, even though the acadiso.pat file seems to be correct?
Thanks!
