Revit, ICT to Solibri
1 REPLY 1
dace.grikite
281 Views, 1 Reply
Hello!
I have started a stage where I need to implement an ICT file from Revit into Solibri. I have had difficulties to work with Solibri rule (209 - Floor space check), because it does not recognize placed furniture to check the rule. (Even if everything is classified).
Solibri support team said that I have not placed spaces in my Revit, ICT file. Does anyone know how to do it?
Hope someone can help,
Best regards, Lina
1 REPLY 1
th95M9M
in reply to: dace.grikite
Have you changed the rule set?
Can you run other rules with ifc space check?
Does rvt file contain room?
Many years ago I have used solibri, but am pretty sure a standard export from revit is enough 🙂
Forma Design Contest
Technology Administrators
