Revit freezes when clicking on a textbox (e.g. Description under Identity) in Material editor dialog in Revit 2022.1.6 and 2023.1.4
RuoqianLu
Autodesk Autodesk
Message 1 of 64
RuoqianLu
Products and versions covered:
Revit 2022.1.6 Revit 2023.1.4
Issue:
When clicking on a textbox control in the material editor dialog, Revit hangs up and stops working. This issue happens to all textbox controls (e.g. Name, Description, Comments, Mark, etc.), which allow users to input texts, in the Material editor dialog.
Causes:
This was introduced by the QT library version upgrade in 2022.1.6 and 2023.1.4, which was to mitigate security vulnerabilities.
Status:
Product team is investigating it and we will update with the information as available.
Ruoqian Lu
Revit Sr. Product Owner
Autodesk, Inc.
Replies (63)
Message 61 of 64
SLuceWUHBM
Awesome thanks!! My explorer trick wasnt working this time around and tried this and it did it! I uplugged my other monitor (not the one that revit froze on) and it changed the resolution of my main monitor... then worked!
Nice to have two potential solutions to this. If i subconsciously highlight again and freeze Im going to try rotating primary monitors and changing resolutions to see if that doesit.
Save often guys!
Message 62 of 64
patall_scenoplus
I tried the explorer also and the HDMI, but it didn't do the trick.  What worked for me is to change the windows Display zoom parameter from 100% to 125% and apply.  Bringing back to 100% after.
Message 63 of 64
SLuceWUHBM
This has worked for me all day. I think this is the trick. All the other solutions sometimes do this rescaling as part of their process. but this is the easiest and quickest.
Message 64 of 64
patall_scenoplus
2022.1.8 Hotfix realeased finally fixed it!  installed this morning
