Revit freezes when clicking on a textbox (e.g. Description under Identity) in Material editor dialog in Revit 2022.1.6 and 2023.1.4
RuoqianLu
Autodesk Autodesk
Message 1 of 64
RuoqianLu
Products and versions covered:
Revit 2022.1.6 Revit 2023.1.4
Issue:
When clicking on a textbox control in the material editor dialog, Revit hangs up and stops working. This issue happens to all textbox controls (e.g. Name, Description, Comments, Mark, etc.), which allow users to input texts, in the Material editor dialog.
Causes:
This was introduced by the QT library version upgrade in 2022.1.6 and 2023.1.4, which was to mitigate security vulnerabilities.
Status:
Product team is investigating it and we will update with the information as available.
Ruoqian Lu
Revit Sr. Product Owner
Autodesk, Inc.
Replies (63)
Message 41 of 64
_dalewfd
It's not working fine, see a few posts up where autodesk acknowledge there is a bug in the latest updates (highlighting text in any of the information text fields).
The initial bug report was posted almost 3 months ago, and the material browser for R22 and R23 is still causing freezes, even after an update to correct the issue. I can't even begin to imagine how much work has been (and continues to be) lost across the board. I fully appreciate that there's no malice here and some people at autodesk are probably just as frustrated as we are, but a lot us aren't really feeling like a 'thank you' is in order here...
Message 42 of 64
stephanie.zhouQE5VB
Could you kindly provide more details about the conditions on how the user run into the freeze issue? Did the issue occur on Revit2022.1.7?
Stephanie Zhou
Revit Sr. Quality Assurance Engineer
Autodesk, Inc.
Message 43 of 64
alexlakin
Hi Stephanie,
It is working fine now but it did freeze a few times on Monday.
This is after I had updated to the latest update.
Not sure what cause it but will let you know if it happens again and will note down exactly what happened.
Message 44 of 64
michele.mollet
This issue went away after 2023.1.5 update and since today it seems to be back.
To stop Revit from freezing you'll need to rescale te resolution of the screen. But it's often still not possible to change the value of the texts in the material browser.
Message 45 of 64
machycekF254L
Do you have any update about this bug (e.g. when we could see update)?
Thank you for idea of workaround. We have same issue in 2023.1.5 and for us it also works when we just simply click into Comments and navigate by Arrow keys. Then we can simply delete and add text without freezing. You just can't highlight text by cursor.
Message 46 of 64
patall_scenoplus
Our office did update to 2022.1.7 and we are still having the same issue trying to modify text on the right side panel of materials.  freezing for over 30min and have to make Revit crash to work again.  No addins installed.
Message 47 of 64
patall_scenoplus
Message 48 of 64
neastland
Community Visitor
Community Visitor
I am having a user experience the same issue as well - Revit 2022 1.7.
Message 49 of 64
stephanie.zhouQE5VB
Thanks for reporting this issue to us. Could you provide some details of the freeze conditions? Did you use mouse to click or hover on any texts or just simple type in texts in textbox?
Message 50 of 64
patall_scenoplus
click in the text box, select text to change the text. screen capture attached.
Message 51 of 64
stephanie.zhouQE5VB
Thank you for providing the details of the problem reproduction. Currently, mouse click to highlight text in material browser will cause Revit freeze is a tracked known issue for us. The team has raised it to the highest level of attention and is working hard to fix it. We will release it as soon as possible. The temporary workaround is:
1.Select all strings in textbox(double click to select some parts of strings) and make copy/paste/edit text actions to avoid the freeze
2.Double click to highlight and select some parts of strings and make copy/paste actions to avoid the freeze.
Message 52 of 64
alexlakin
Just an update, sorry for leaving this for so long had other priorities. I personally have not had any further issues since posting last. I have several versions of Revit (2022 and 2024) but no add-ins as I have lost confidence in adding any in case the problem reappears.
I have a work around if using a material tag where you can edit the identification information for the material without freezing. However, it has not happened since but will be sure to update you if it happens again.
Message 53 of 64
jsafah
I fixed this for a user by installing the latest Revit 2022 update via "Product Updates" in Autodesk.com.
However, it didn't work for one of my users. They instead used a workaround: If you backspace delete instead of highlight delete, Revit will not crash.
Hope this helps.
Message 54 of 64
neastland
Community Visitor
Community Visitor
Thanks to everyone for the reply's to my message above.
We have been able to workaround the issue by using the keyboard to navigate through the changes instead of using the mouse, as everyone else has said.
So at least there is an easy way around the issue.
Message 55 of 64
SLuceWUHBM
When I accidently use mouse to highlight, I am able to unfreeze Revit by opening windows explorer on the monitor that Revit is located, maximizing it, then closing it.
Probably some for of windows problem conflicting with the revit code.
Message 56 of 64
SLuceWUHBM
When revit freezes due to this bug, I am able to unfreeze the program by opening windows explorer on the monitor that revit is located, maximize the window, then close the window quickly.
Message 57 of 64
Adrian5D
Hmmm, got every Revit-version up to date.. Still got the problem in Revit 2023.. hoping for new update where the problem is actually gone...
Message 58 of 64
_dalewfd
No idea how you stumbled on this solution but it just worked for me, thanks for sharing.
Message 59 of 64
ben_vawdreyZULWG
Hi guys, the explorer window thing didn't work for me but it got me thinking (in a panic as to not loose a lot of work)...so I unplugged the hdmi from my second monitor and voila, Revit reset itself and I could save. Good times.
Hope this helps someone!
Message 60 of 64
dw_greyblock
god this is annoying
