Revit families: How to parameterize an inclined reference plane to move horizontally by a dimension?
4 REPLIES 4
MCalza
1071 Views, 4 Replies
I have the family .rfa that I attach and it can be seen in the next picture (picture 0):
I want to modify the dimension A, and that the inclined plane extrusion moves with it (see picture 2). I don't want is that it do and you can see at the next picture 1:
 That's I want to do (picture 2):
Do you know how to do it?
Any advice or suggestions?
Thank you
4 REPLIES 4
in reply to: MCalza
Use a Reference LINE in Elevation View and host the element to the top of this Ref. Line/Workplane in Plan View.
Here. Something along these lines...
in reply to: MCalza
Revised one:
syman2000
in reply to: MCalza
Reference Line is the way to go like @barthbradley said. Make sure you have a reference plane where you define the start of the angle. Alternatively you can also use nested family to flex it so you don't need reference line. See attached
in reply to: syman2000
I would definitely agree (and urge) that the element being driven by the angled Ref. Line be a nested family (Work Planed Based) and hosted to the Parent Family Ref. Line.
Forma Design Contest
Technology Administrators
