I have the family .rfa that I attach and it can be seen in the next picture (picture 0):
I want to modify the dimension A, and that the inclined plane extrusion moves with it (see picture 2). I don't want is that it do and you can see at the next picture 1:
That's I want to do (picture 2):
Do you know how to do it?
Any advice or suggestions?
Thank you
Solved by barthbradley. Go to Solution.
Use a Reference LINE in Elevation View and host the element to the top of this Ref. Line/Workplane in Plan View.
Here. Something along these lines...
Reference Line is the way to go like @barthbradley said. Make sure you have a reference plane where you define the start of the angle. Alternatively you can also use nested family to flex it so you don't need reference line. See attached
I would definitely agree (and urge) that the element being driven by the angled Ref. Line be a nested family (Work Planed Based) and hosted to the Parent Family Ref. Line.
