Revit Exporting Issue(Some plans are missing )
josemukalel
josemukalel
REVIT.PNGpdf.PNGPlease have a look on both Images.First one is captured from Revit sheet ,That is perfect.But while I am creating PDF the last levels of staircases are missing.Anybody can help please to find the solution ?
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
Try to use a different PDF printer.  If it still doesn't work, try export to DWF then create PDF from the DWF.
