revit export - IFC options missing
5thSth
5thSth
hi,
I have been looking at this tutorial, and at one moment they go to "Export>IFC Options". I do not see that feature in my revit. has it been removed, or am I missing a plugin?
eizinmyat
As I think you have the same case like this, how about trying it? I attached the link so that you can check.
https://forums.autodesk.com/t5/revit-structure-forum/i-don-t-have-ifc-option/td-p/7991116
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
5thSth
the solution is the problem. I'm missing the button in the Options subcategory.
TripleM-Dev.net
Hi @5thSth,
You might need to scroll down in the menu, or press the scroll "bar" at the bottom (or top)
Depending version there may be more item in the menu.
Ps. What Revit version?
- Michel
