I have only used the "mirror project" once before some time ago and it went perfectly.
Doing it now manage/ position/ Mirror project/ choose axis, there is no prompt for where the project will be stored. I cant find it anywhere on my computer or in the cloud (autodesk Docs). The source model is autodesk cloud based. I've also tried downloading to A local folder, the mirrored file is not there when I loo for it after mirror the local based model.
How do I spec a place for the mirrored project to go? Or where does it go by default, if that can't be controlled?
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Mirror project does not create a new file so it should still be wherever the file was to begin with. If you intended to mirror a copy of the project, not the original, you'd need to save it first. If it is hosted on ACC you'd have to download the file to your local PC, open, save and the use Collaborate in the cloud again to put the new file back in the ACC project.
Steve Stafford
Thanks. That's hilarious because I looked everywhere except AT the (now mirrored) project on the screen.
I had saved that project to a new name, now it exists ONLY as the mirrored project, just as you said.
