REVIT ERROR
REVIT ERROR
Message 1 of 12
REVIT ERROR
I am using Revit 2014...today I started getting this error appearing in Notepad when I try to print to Adobe PDF. Any suggestions? Or known causes? Solutions?
%%[ ProductName: Distiller ]%%
%%[ Error: undefinedresult; OffendingCommand: imageDistiller ]%%
Stack:
-dict-
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
Replies (11)
Message 2 of 12
FAZIOGREG
Open up the Adobe print settings [Start>Devices and Printers>right click on "Adobe PDF">Printer Properties].  Click on the Advanced tab and check "Enable Advanced Printing Features"
Let me know if that works first, then we can try other things if that doesn't work.  Did you recently update Adobe or Revit?
Message 3 of 12
I am receiving a similar error. I havent printed much but it seems that sheet size 30x42 works fine but 24x36 is where the error occurs.
I have tried clicking the 'Advanced printing' option with no luck.
Stack:
-dict-
Running Revit 2016
Any help would be much appreciated
Message 4 of 12
diegus68
I discovered that the problem disappeared when I change a PNG image embedded in my Title Block family for the same image but in JPG
No more problem crating a PDF
Revit 2020
Message 5 of 12
This was exactly my problem! Thanks so much!
Message 6 of 12
JHeilman258
changing the *.png to *.tif resolved this issue for me. Using revit 2020 and acrobat Distiller DC.
Message 7 of 12
lim.wendy
Hi @Anonymous,
Welcome to the forum and thanks for reaching out to the forum. It looks like @diegus68  found the solution to this issue. So for now I am going to mark this as "Solved". This won't prevent other users from commenting on this question though in the event other ideas come up!
Have a great day!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 8 of 12
Had the exact problem today for the first time. I've used hundreds of .png images before with nary a problem, but deleting the offending image solved it. Kudos !
Message 9 of 12
mcobb
The problem is definitely with png processing. Curiously a png (call it png A) printed on one sheet (call it sheet 1) works. Printing png A on another sheet 2 with png B does not work. Printing png B without png A on sheet 2 does work. All very weird. I need to use png images here and not jpegs. Sad....Any further advice is appreciated.
Mike
Message 10 of 12
TrishHad
Swapping from png to jpg fixed my printing errors - thank you!!!
Message 11 of 12
espuela.91
Community Visitor
Community Visitor
THANKS!
Message 12 of 12
mvinsonK27ER
use ( mircosoft to pdf ), it work for me
