Revit crash when click on site settings
Message 1 of 15
I have one revit template and my revit crash every time I try to access to the Site Settings in these file or in a project started with this template.
 Does anybody know what is the reason for it??
Regards
Replies (14)
Message 2 of 15
ennujozlagam
@Anonymous hello, have you try to install latest updates from autodesk sometimes it fix issues. thanks
Message 3 of 15
@ennujozlagam Hello, Yes I have my Revits updated to 2018.2 and 2017.2.2
Message 4 of 15
markcalloway
Hi @Anonymous
It is possible this project is corrupt if it only crashes in this one project.
You can try fix the project by running an Audit when you open it:
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/ENU/Revit-GetStarted/files/GUID-863142B6-3DB6-486E-BEA6-0B6757C2E759-htm.html
See if this fixes this fixes anything and stops the crashing. Let us know how you get on.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Message 5 of 15
@markcalloway wrote:
Hi @Anonymous
Hello @markcalloway
I have tried and audit the file, and it did make anything, I didn't have any message coming or anything, just the file open normally. And then, it crashed again when I try to access to Site Setting
Also, in the same file I am having some graphic issues, I do not if they are related, probably they are, but see in my other post
https://forums.autodesk.com/t5/revit-architecture-forum/template-corrupted-with-graphic-issues/td-p/7487103
Message 6 of 15
Do you have any model elements in the file? How far are they from the Origins?
Message 7 of 15
I have one project file with a whole project, and I moved the base point and survey point to the center of the building.
Also, I have the template we used for this project, and it is empty, purge as much as I could, Origin in the middle of the view.
And in both cases it crash.
Also, I have removed all addins from Revit
Message 8 of 15
Attached is a project started with the template which is the origin of all the problems, It also crash when you access to site settings
Message 9 of 15
ennujozlagam
@Anonymous hello, i managed to recover your file. what i did i open a new file i transfer project standards (copy only new file) save, then solved your issues. thanks
Message 10 of 15
Hello @ennujozlagam
Did you transfer project standards from the new project open with the Revit default template to my project file, or you did the other way around??
Message 11 of 15
ennujozlagam
open a new file transfer project standards to your project 1 file. thanks
Message 12 of 15
Hi @ennujozlagam
It resolve the problems with Revit Crashing when click on Site settings.
But I still having those graphic issues I posted in the other thread
https://forums.autodesk.com/t5/revit-architecture-forum/template-corrupted-with-graphic-issues/m-p/7...
Thanks for your help
Message 13 of 15
Hi @ennujozlagam
I have been researching more about what was the problem, transferring project standards in small package to find which one was the problem. Obviously it was the site settings.
If I transfer the site setting using the tool transfer project standards from a new revit default template, to my template, and it solve the problem of crashing every time I click on site settings. But the other graphic issues are still there.
Thank you so much.
Regards
Message 14 of 15
ennujozlagam
No worried glad to help. It is difficult to check the problem without the file unless you want to share the file thanks
Message 15 of 15
I am willing to share the project, I can't leave it open to everybody due to privacy issues but I can share is individually.
I have send you a link with the model in a private message
