Revit columb plaster problem and section back lines problem
jhdrvn65
Message 1 of 8
jhdrvn65
 Hello, I'm new to Revit, I have 2 problems. The first is the intersection of the column and wall plasters, the plasters surround the column, I do not want this to happen, I want the reinforced concrete wall to intersect with the wall, how can I do it?
My second problem is that when I cut sections in Revit, I sometimes want to show some lines in the background as dashed lines. I couldn't find a way. I would be glad if you could help me.
Replies (7)
Message 2 of 8
Switch Join Order or use a Structural Column
Message 3 of 8
jhdrvn65
The structural column is already the same. The plaster materials are the same and this is what happens when the order of joining is changed.jhdrvn65_0-1703957949131.png
Message 4 of 8
Regarding #2, increase the far clip distance to include the beyond roof and use Silhouettes.
Message 5 of 8
jhdrvn65
No, I didn't mean beyond. I meant the part of the roof behind where I took the cross section.
Message 6 of 8
I'm not following.  I can see by the behavior that you are using an Architectural Column.  Show me a screenshot of the unjoined condition.
Message 7 of 8
Behind the View? No can do.
Message 8 of 8
yes_and_no
How about setting further view clip and use match line tool.
OR set roof cut line to be much bolder than projection line, like 5 vs 1.
