data set files for Revit
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
incredibleazure
715 Aufrufe, 2 Antworten
it is my first time using Revit, I'm having a look to the guide on the site autodesk.com.
When it is explained how to insert doors, I don't find any type of door except for the single flush door. And it is said "If you don’t have these folders or families, copies have been provided with the dataset files".
Where can I find dataset files???
Best regards,
Anna
2 ANTWORTEN 2
Nachricht 2 von 3
Alfredo_Medina
als Antwort auf: incredibleazure
From the Insert menu, use "Load Autodesk Family", then search for one or more families and load it/them into your project.
Nachricht 3 von 3
I think the term "data set" is referring to the materials included with the tutorial you are following.  As far as for Revit  Door Families, there are numerous sources for door families on-line.  For example, BIMObject.com.  Or go direct to the Door Manufacturer's Website. Many provide RFAs of their Products, including Pella and Marvin.  Or just Google "Revit Door Families".  I guarantee you'll get plenty of hits with those 3 search keywords.
