Revit closing when loading tool help menu
Message 1 of 9
Good afternoon, I'm having problems when I try to open a tool's help menu.
When I place the mouse over the tool, after opening the tool's help menu, revit freezes and then closes.
can anybody help me?
video:
https://drive.google.com/file/d/1k-3XwlUTAvhYPLO5YnHFNr3uU14HPuKd/view?usp=sharing
Replies (8)
Message 2 of 9
Go to Options=>User Interface=>Tooltip Assistance and try a different setting.
Message 3 of 9
When I leave it at the Minimum it resolves, but I wanted another way to resolve it so I could view the tip assistance.
Message 4 of 9
TripleM-Dev.net
Couldn't find a specific Error page for this.
But read this Troubleshooting: Tooltips , and see if you're system can play Mp4's normally
- Michel
Message 6 of 9
TripleM-Dev.net
@barthbradley , think that's a old one.
Flash is no longer used from Revit 2016 up I think, the links I provided refer to R2019/2020 as using MP4 video
AutoDesk should embed a lightweight player so it's not depending on a player of the system.
Message 7 of 9
As I did not find a way to continue showing, I will remove the tooltip.
Message 8 of 9
TripleM-Dev.net
Did a search, thought the video's would be embedded somewhere, but they are stored as seperate mp4 files.
See the following location: C:\Program Files\Autodesk\Revit 2020\videos\ (or other Revit version)
Can you play them outside Revit?
Message 9 of 9
I can reproduce normally.
