unable to edit this stair handrails
Dear all
am unable to edit this handrails ..
i have two flights
when i go to fix this handrails i won't be able to fix
Hope you experienced guys can help me in this
Thank you so much
Post the file
ennujozlagam
try to separate railings one flight each and see if helps. thanks
Thank you so much for your response..
it may work but i should create unnecessary levels in between
with out adding levels any other easier way ?
hope you would understand me Thank you
No need to create additional level to correct this. The fix is easy. Post you file.
