Revit closing randomly
Message 1 of 11
I work in IT for a school system. Our architectural drafting and design teacher is reporting that on their teacher computer revit closes randomly all day long, they will be in the middle of demonstrating something and it just locks up and crashes, and she has to relaunch the software to resume teaching. I am not there to witness this happening, so I pulled the whole appdata directory for revit from her computer and was trying to figure out what is going on but I don't really know exactly what i was looking for. In journals there are dump files but they don't seem to contain much information.
Replies (10)
Message 2 of 11
The Journal files will show something like "Exception" before a crash, so look into the journal files to see what happens before the crash - it may indicate what's happening.
Find out if this happens in different files, or is there a particular file that crashes.  If it is one file, open it with Audit.  The errors are listed between Begin dump and end dump.  This might indicate the problem.
Message 3 of 11
Okay I found some journals that were completely empty, not sure what that is about, but I looked at one that actually contained something and one had one mention of exception in it, but it doesn't appear related to a crash, every journal seems to include this line:
0:< 4.7.03190(461814)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
The section where it says dump there is nothing between the start end of the dump but other stuff near it looks possibly related. Here it is:
' 7:< ::263:: Delta VM: Avail -9 -> 134177644 MB, Used 1062 MB; RAM: Avail +13 -> 9941 MB, Used +1 -> 1213 MB, Peak +1 -> 1213 MB
' 7:< GUI Resource Usage GDI: Avail 9065, Used 935, User: Used 595
' 5.600856!!!!!!!! 7:!!!BIG_GAP ADocumentUpgrade::docUpgrade [H:\prosser lessons\Revit\WALL SECITON NEEDED.rvt]
' 0.347114 7:<<overall delayed deletion from upgrade
' 6:< ======== BEGIN Dump Content Doc Tree (upgrade) ========
' 6:< ======== END Dump Content Doc Tree (upgrade) ========
' 6:< ::263:: Delta VM: Avail -15 -> 134177629 MB, Used +15 -> 1078 MB, Peak +10 -> 1078 MB; RAM: Avail 9941 MB, Used +6 -> 1219 MB, Peak +6 -> 1219 MB
' 6:< GUI Resource Usage GDI: Avail 9065, Used 935, User: Used 587
' 6:< Unnecessary nesting;Document\TrustedUpgrade.cpp;1624;ID_REVIT_FILE_OPEN ;N++E(N);
'10:< Unnecessary nesting;Family\FamilyDocument.cpp;560;ContentADoc__UpdateReplicasInSmallDocStep;N++E(N);
'12:< Connecting session [$32051a5e] to Worksharing Log [C:\Users\chamilton\AppData\Local\Autodesk\Revit\Autodesk Revit 2019\Journals\journal.0063.txt]
'12:< Additional IP address/name found for host 90-T-CHAMILTON: 10.90.6.96
'10:< FaultyAtomsCheckLog - Comparasion difference found :
It keeps going with many entries of unnecessary nesting. Some other text i saw that looked interesting was:
' 0.134760 12:<<;PERF;MISC;regenerating
'22:< ::263:: Delta VM: Avail -2 -> 134177628 MB, Used +3 -> 1081 MB, Peak +3 -> 1081 MB; RAM: Avail -8 -> 9934 MB, Used +10 -> 1229 MB, Peak +10 -> 1229 MB
'22:< GUI Resource Usage GDI: Avail 9060, Used 940, User: Used 596
'22:< DBG_INFO: ConeSurf constructor called with a half-angle not in the range (0, PI/2): 3.054326.: line 80 of ConeSurf.cpp.
' 0.152997 12:<<;PERF;MISC;regenerating
'10:< REGEN_DOC_CONTEXT_INFO: Known attempt to modify wrong element during regeneration
Message 4 of 11
Could be an Add-in the teacher is using.  If teacher disables Add-ins, does the problem go away?
Message 5 of 11
I found what i think looks like a crash event:
'CT [Modify | Walls]:
' {1} spacer_shr
' {10} Dialog_HostObj_SketchEditElevation_a
' {20} Dialog_HostObj_SketchEditElevation_b
'<<End update Provider-triggered panels>>
'E 18-Oct-2019 08:25:30.676; 0:<
Jrn.MouseMove 0 , 0 , 150
Jrn.PropertiesPalette "Activate"
'E 18-Oct-2019 08:25:30.678; 0:<
Jrn.PropertiesPalette "ClickTS"
' 0:< ;PERF;MISC;ElementsGraphicCacheUpdater::updateAll() DBViewProject id=275: 959(100%) elements need cache update
' 0:< ::61:: Delta VM: Avail 134178261 MB, Used -3 -> 646 MB, Peak +9 -> 658 MB; RAM: Avail -17 -> 10667 MB, Used +12 -> 806 MB, Peak +13 -> 807 MB
' 0:< GUI Resource Usage GDI: Avail 9205, Used 795, User: Used 487
'E 18-Oct-2019 08:25:33.595; 0:<
Jrn.RibbonEvent "ComboCurrentChangedEvent:TypeSelector:Exterior Shingle Over Brick w Wood Stud:Stacked Wall"
' 0:< Unnecessary nesting;FamilyDialogBarImpl_4;-1;ID_CHANGE_SYMBOL ;N++EB(NB);
' 4:< FaultyAtomsCheckLog - Comparasion difference found :
' 4:< Snapshot - Two edges (473 474) don't meet on face 477
' 4:< DBG_INFO: ComputeSnapshotGeomChangeInfoStep::reconstructPrevGRep failed in ComputeSnapshotGeomChangeInfoStep::setSnapshotGeomChangeInfo.: line 3399 of d:\ship\2019_px64\source\revit\revitdb\regen\GeomStepList.cpp.
' 4:< DBG_INFO: setSnapshotGeomChangeInfo failed. Please look at previous journal entries and file a bug.: line 3785 of d:\ship\2019_px64\source\revit\revitdb\regen\GeomStepList.cpp.
' 4:< Snapshot - Two edges (171 172) don't meet on face 173
' 4:< Snapshot is constant
' 4:< Snapshot is constant and really did nothing
' 4:< Snapshot - Two edges (71 72) don't meet on face 75
' 4:< REGEN_DOC_CONTEXT_INFO: Changing wrong atom in regeneration
' 7:< ::62:: Delta VM: Avail +12 -> 134178274 MB, Used +4 -> 650 MB; RAM: Avail -6 -> 10662 MB, Used +3 -> 810 MB, Peak +2 -> 810 MB
' 7:< GUI Resource Usage GDI: Avail 9207, Used 793, User: Used 489
' 7:< MODIFICATION IS FORBIDDEN: Element modification is forbidden because it is a member of a family, and that family is not being edited.
' 4:< ::62:: Delta VM: Avail -28 -> 134178246 MB, Used +16 -> 666 MB, Peak +8 -> 666 MB; RAM: Avail -7 -> 10655 MB, Used +7 -> 817 MB, Peak +7 -> 817 MB
' 4:< GUI Resource Usage GDI: Avail 9207, Used 793, User: Used 489
' 4:< FaultyAtomsCheckLog - failure posted from faulty step. FaultyStep - [UpdateSubWallsForStackedWall of SWall {*} (-*: UpdateSubWallsForStackedWallStep)], FailureMessage - [Wall is shorter than minimum height allowed by its type.
'It is *' - *" and must be at least *' - *".],
' 4:< Error posted:
' 4:< Wall is shorter than minimum height allowed by its type.
'It is 6' - 0" and must be at least 7' - 0".
' 0.820622 2:<<;PERF;MISC;regenerating
' 0:< ;PERF;MISC;ElementsGraphicCacheUpdater::updateAll() DBViewPlan id=369: 130(55%) elements need cache update
'H 18-Oct-2019 08:25:34.618; 0:<
Jrn.Data "Restricted Propagation" _
, 2, 95
' 0:< ::62:: Delta VM: Avail -2 -> 134178244 MB, Used 666 MB; RAM: Avail -11 -> 10644 MB, Used +6 -> 824 MB, Peak +6 -> 824 MB
' 0:< GUI Resource Usage GDI: Avail 9208, Used 792, User: Used 482
' 0:< Exception occurred
'C 18-Oct-2019 08:25:34.632; 0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFD80EFE98B
' 0:< BC: 0,0,1
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 10649 / 16309 824=InUse 824=Peak
' 0:< VM Statistics: 134178245 / 134217727 666=InUse 666=Peak
' 1:< ::62:: Delta VM: Avail +7 -> 134178251 MB, Used -9 -> 657 MB; RAM: Avail +102 -> 10746 MB, Used -1 -> 823 MB
' 1:< GUI Resource Usage GDI: Avail 9208, Used 792, User: Used 475
' 1:< Revit worker 1 closed cleanly
' 0:< [000028d4]QueueMinder stopped
'C 18-Oct-2019 08:25:35.706; 1:< logging finished virtualization services
'C 18-Oct-2019 08:25:35.706; 1:< logging finished worker services
'C 18-Oct-2019 08:25:35.708; 1:< logging erased queues
' 1.070567 1:<<<Terminating Slave Processes
' 0:< ::62:: Delta VM: Avail +33 -> 134178285 MB, Used -1 -> 656 MB; RAM: Avail +25 -> 10772 MB, Used 823 MB
' 0:< GUI Resource Usage GDI: Avail 9206, Used 794, User: Used 457
' 0:< DBG_INFO: An active transaction phase on the stack while UndoMgr has no transaction currently open!: line 4966 of d:\ship\2019_px64\source\revit\revitdb\undo\UndoMgr.cpp.
' 0:< DBG_WARN: Unexpected Undo Commit Phase!: line 5196 of d:\ship\2019_px64\source\revit\revitdb\undo\UndoMgr.cpp.
' 0:< DBG_INFO: UndoMgr stacking is out of sync after finishing a transaction: line 1139 of d:\ship\2019_px64\source\revit\revitdb\undo\UndoTransaction.cpp.
' 0:< Unconverted MessageBox "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects.
'Would you like to save a recovery file?"
'E 18-Oct-2019 08:25:42.921; 0:<
Jrn.AddInEvent "AddInJournaling" , "MessageBox(YesNo,Revit).Click(No)"
'H 18-Oct-2019 08:25:42.927; 0:<
Jrn.Data "MessageBox" _
, "IDNO", "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects. " & vbLf & "" & vbLf & "Would you like to save a recovery file?"
'E 18-Oct-2019 08:25:42.927; 0:<
' [Jrn.AutoConvertedMessageBox] Rvt.Attr.MessageId: IDS_UNRECOVERABLE_ERROR Rvt.Attr.MessageAnswer: IDNO
'C 18-Oct-2019 08:25:42.927; 0:< program terminated
Message 6 of 11
I found what looks to be a crash report in one journal.
' {1} spacer_shr
' 4:< Error posted:
, 2, 95
' 0:< BC: 0,0,1
Message 7 of 11
They are not using any add-ins.
Message 8 of 11
Here is what looks like an exception in a journal file.
' {1} spacer_shr
' 4:< Error posted:
, 2, 95
' 0:< BC: 0,0,1
Message 9 of 11
Make sure all the updates are installed.  File may have been a newer version than what is installed.
Message 10 of 11
I have tried multiple times to paste some of the journal log but it deletes my post instantly as "spam" so i'm attaching screenshots of the log. I found a spot that appears to be one of those exceptions that resulted in the application closing.revit error 1.JPGrevit error 2.JPG
Message 11 of 11
ennujozlagam
worse scenario? try to do a clean uninstall and reinstall again the program and install updates. it could be some files are corrupted. just saying. thanks
