Revit certified professional exam
Message 1 of 19
hi guys...
I'm looking for some free resources to study for the Revit Professional exam?
maybe links for you tube channels ?
websites.. lectures .. samples..
anything that would help me achieving my goal
thanks a lot
Accepted solutions (4)
Replies (18)
Message 2 of 19
rudi.roux
Hi @Anonymous,
Hope you are well! Smiley Happy
I would review some of my comments from my original post regarding the AutoCAD certified professional exam as they are also relevant for the Revit Exams.
A couple of additional pointers are the following:
  • Pick the Revit Exam which suits your profession the best (you could always do all of them, but maybe start with the discipline which you feel most comfortable with).
  • The general “word on the streets” is that the Revit MEP exam is the hardest one opposed to Architecture and Structures.
  • You can choose between the following 3x Revit Certified Professional Exams: MEP, Architecture or Structure.
  • You can choose to write the 2015 exam versions or the current versions. HAVE A LOOK HERE
One of the top reasons why people fail the exams is due to time management in the exams. To increase your proficiency/speed is to learn Revit Shortcuts early on, or start using them. The next thing is, the desktop which you write use to write your exam might not be the fastest desktop ever, so I generally open the exam files prior to opening the exam. There is time to do it while you read through the exam rules before starting the actual exam.
Here is a list of e-books which you could use as learning material:
REVIT MEP
REVIT ARCHITECTURE
REVIT STRUCTURE (a bit outdated)
CADLearning is a great resource… (for me prior to exams… they also have “Overall Knowledge” and “Skill Assessment Tests” which could also help…)
Good luck with all the learning! Smiley Wink
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 3 of 19
rudi.roux
@Anonymous, here is also a list of Revit training resources (videos) on LYNDA
You might also want to have a look at Autodesk University videos or you could try the Revit training videos available on Autodesk Design Academy - both of the last mentioned resources have free training videos.
I hope this helps! Smiley Wink
Rudi Roux
LinkedIn
Message 4 of 19
BIM.Consultant
Revit Architecture: 2015 Certified Professional Exam Preparation Class:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2014/revit-for-architects/cp1404#ch...
BIM Consultant
Message 5 of 19
hi Rudi...
i did the Auto cad 2015 professional two days ago and i passed it .. relay appreciate your help.. the references you mentioned helped me alot to pass the exam although i'm pretty good in autocad but the exam is something different. 🙂
now I'm planning to study the revit .. I'm not that good in revit.. i know little about it so i need to study really hard to pass the professional exam....
my background is architecture .. i studied architecture engineering so i guess architecture revit will be easier for me in this time
Message 6 of 19
i will be studying all these references u mentioned .. u r awesome .. i really appreciate your help.
i have the following two books .. i might study with consideration to the one you mentioned .
Message 7 of 19
is the classes for free???
and by the way i wanna ask you how i can add my badge just like you ?
i have it for the autocad but i dont know how to attach it with my name?
would you help!
Message 8 of 19
rudi.roux
Hi @Anonymous,
Yes, that class is for free, there is a couple of good pointers prior to the exam on the AU website.
As for your signature, I created one for you. Download/Open the attachment, it is a Notepad file containing code which you require for your signature to look like this:
In the code which I provided, open it and edit one small thing, remove only the XXXXXXX's and put your Acclaim name as featured in your Acclaim URL where the XXXXXXX's currently appear.
Where to find you name in the mentioned URL?
After you replaced your name in the code, Ctrl+A (Select All) the code followed by Ctrl+C (Copy) and then Ctrl+V (Paste) the code under your Community Account >> Preferences >> Personal >> Personal Information >> Signature.
Rudi Roux
LinkedIn
Message 9 of 19
rudi.roux
@Anonymous - Back to your exams. haha - Firstly, congrats on passing your AutoCAD Exams! I'm very glad that my pointers helped you achieve your Goals! Did you use the advice which I gave you regarding registering with the Student Expert Network? I would strongly recommend it for preparing for your Revit Exams. Here is a glimpse of all the free resources which I have at my disposal:
It doesn't look like I use much of it, haha, but I've been on Revit for about 7/8 years, so I use it only to review a couple of things when needed. CADLearning really helps some of our inexperienced/junior staff apart from my hands-on training. I'm going to start reviewing a couple of things under the Revit Architecture section as I'm also writing that exam in the next couple of weeks.
Hope this helps! Smiley Wink
Rudi Roux
LinkedIn
Message 10 of 19
yeah its help.. everything you mentioned and post is working perfectly ..
i did my signature as you told me , lets see it now after posting th
Message 11 of 19
thank you rudi.. u r really great person.. thanks for helping.. my signature is so beautiful and i love it...
i will register for Student Expert Network! and hope i can do the exam with maximum two month from now.
hope u will do well...
very best,,
Noora
Message 12 of 19
rudi.roux
Hi @Anonymous,
It looks great! I'm glad I could assist and thank you for the kind words. Smiley Happy
Kindly accept the post/s which provided a solution for you so that future community members could also benefit from it.
Good luck with your studies and let me know how it went! Smiley Wink
Rudi Roux
LinkedIn
Message 13 of 19
Thanks for sharing these great resources. I came here looking for advice on the Revit certified professional and was wondering if anything has changed since the last post. I am scheduling my exam in a week and wanted to make sure I pass it the first time around. So far ive completed the lynda.com revit essentials training and the revit certified professional test prep courses.
Message 14 of 19
did you pass that exam?
Message 15 of 19
Yes i did with a 900!
Thanks for the support and resources
Message 16 of 19
I jumped for joy!
Message 17 of 19
What materials did you end up using to study? Only the Lynda videos?
Message 18 of 19
How much did the exam cost?
Message 19 of 19
DarrenP
you can go here for that information: http://shop.certiport.com/category-s/1900.htm or talk to a certification center in your area
DarrenP
