Moving decimal in Space Schedule spreadsheet
2 ANTWORTEN 2
Nachricht 1 von 3
335 Aufrufe, 2 Antworten
When creating Space Schedule spreadsheet for Heating and Cooling loads from Schedule/Quantities, the decimal place is off by a couple of locations. When calculating BTU/H formula manually compared to Revit worksheet the decimal place is off by couple of number places.
How do you reformat the decimal placement like you can in Excel to move the decimal location.
See the attachment
2 ANTWORTEN 2
Nachricht 2 von 3
Erense
als Antwort auf: Anonymous
You could edit the content by dividing the value through 1000 in a formula.
Or else you could edit the Project settings under Energy - cooling and heating loads. Perhaps just activating the 'use digit grouping' would do the trick.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Nachricht 3 von 3
als Antwort auf: Erense
That wasn't what I needed, changing the units didn't work, the decimal places didn't move. The project is using the project calculations for Heating and Cooling Loads Analysis so you want Revit to use the numbers it comes up with, just have it move the decimal place, with out rewriting or recreating the wheel.
Does anyone have a solution?
Brian W. Clayton
Clayton Consulting and Design, LLC.
2905 Regents Park Lane
Greensboro, NC 27455
336-540-0773 (office)
336-209-1969 (cell)
cconsultdesign@aol.com
www.brianwclayton.webs.com
Clayton Consulting and Design LLC webpage
