REVIT CAN'T DRAW LINES LESS THAN 0.09 mm WIDTH
Message 1 of 24
Hi all¡¡ I am testing the line width that Revit prints because in the program interface my drawings looks cool (with thin lines disabled and all the line style,lines width and so on well defined) but when I print it loose quality...I have compare the lines of Autocad and printing the same line width with Revit and I have detected that in Revit all the lines that are less than 0.09mm are printed with the same thickness, all are printed with 0.09mm....Has anyone check this error?? I have chek it using Illustrator, that shows the width of the line that is in the pdf.
Thanks in advance
Javier
Replies (23)
Message 21 of 24
I have check the thickness of the lines in other programs (illustrator) qs i habe said in the example above, it happens when i print in a virtual pdf printer
Cheers
Message 22 of 24
Cheers
What is the DPI output set to the PDF printer?
Message 23 of 24
Any solution in this topic? I have found similar ones, more people is finding the same error but anyone hasn’t find a solution yet...i cant believe that autodesk is just looking to other place about this huge drafting issue...
Message 24 of 24
chrisplyler
I really don't understand this problem. What printer are you using to print out your drawings that has greater than 120 Lpi? Which is very close to 0.1mm anyway. How are you going to print thinner lines than that?
