Topography
Topography
Topography
Hi, Is it possible to re-position the already place topography?  I thought I had drawn an area at 0mm height but think I set it to Ground and not Street level which is 300mm below.  I've had a look and I can't seem to find anywhere that says what level the topography is based on.  Can anyone help please.  Thanks.
The Project Base Point Elevation
loboarch
This topic form the help may help with the process of getting your topography reading correctly.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-B73E0D49-3330-4876-B8BD-7C23B9340626
Jeff Hanson
Principal Content Experience Designer
Revit Help |
