Message 1 of 24
REVIT CAN'T DRAW LINES LESS THAN 0.09 mm WIDTH
08:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all¡¡ I am testing the line width that Revit prints because in the program interface my drawings looks cool (with thin lines disabled and all the line style,lines width and so on well defined) but when I print it loose quality...I have compare the lines of Autocad and printing the same line width with Revit and I have detected that in Revit all the lines that are less than 0.09mm are printed with the same thickness, all are printed with 0.09mm....Has anyone check this error?? I have chek it using Illustrator, that shows the width of the line that is in the pdf.
Thanks in advance
Javier
