Revit backward compatibility
2 REPLIES 2
299 Views, 2 Replies
Can  I create a family in Revit 2016 at home and import it in Revit 2021 in the office ?
2 REPLIES 2
mauricio_mssf
If it is a loadable family, you can use the load family tool.
If it's a system family, you can open the revit project in the same session (ctrl+o) and use copy (ctrl + c) and paste (ctrl + v).
It works if it goes from an old version to a new one, but not the other way around, it cannot downgrade.
Take a look.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-M...
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-G...
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
syman2000
You can create family in 2016 and open in 2021 at office. However you cannot open 2021 file in 2016.
Forma Design Contest
Technology Administrators
