Revit and immersive design
tonytwok
tonytwok
I have been considering making an investment by purchasing a laser scanner (Leica, Faro...) or the Matterport camera. The systems are completely different just like the prices.
I'd like to simplify the architectural relief and learn the immersive technology.
Does anyone already use these systems or is planning to use them?
alan_eu
Hi @tonytwok
Actually, I´m using the Insta360 camera to create 360 photos/videos and I´m happy with it. It can´t create 3D models by itself, but it´s possible to do this using Recap or even create a full set 360 photos to walk through your building using software like PanoVR or MeuPasseioVirtual.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Mohamed-Nassar
for sure you can convert it to immersive but u need to build your own model before create immersive model like VR or AR, that you mean al right if i have miss understand clarify it to me thanks.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
tonytwok
Which Insta camera do you use?
syman2000
You can take a look at iPhone 12 Pro Lidar as cheap alternative to expensive equipment. You can check out this website and see sample scan from iphone 12 Pro Lidar
https://sketchfab.com/blogs/community/3d-scanning-with-the-iphone-12-pro-lidar/
alan_eu
Insta360 One X used with Matterport could create good looking  3D + 360 tours for free 🙂
