Is there any way to have different sized revision clouds in one model.
I have the need to use smaller arc sizes in different locations
The minimum arc length for the revision cloud shape can be specified in the Arc Length option on the Sheet Issues/Revisions dialog. This setting controls the arc length for all revision clouds in the project.
Yes you can change the minimum arc length in the revision settings before you draw a revision. Or you can draw the cloud segments manually using line tool.
I don't understand the "size" issue. Revision Clouds are Annotative Elements, like Text and dimensions.
Today I was looking at the same issue, and found this option that allow you to change the arc size. hope it helps.
Ahh, thank you! The View>Revisions>Arc Length was overriding my arc length adjustments within the Revision Cloud. Much appreciated.
