Revit A3 sheet with standard title block
tamarlubet
tamarlubet
Community Visitor
Community Visitor
Why are the standard paper size sheets not loaded into my revit? How do I get them loaded in?
vitorbortoncello
The standard paper size sheets, such as A3, are not preloaded in Revit by default.
Go to View tab-Sheet composition-Sheet-Load-Then choose your RFA file
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
edward_silvaMRPT5
Observer
Observer
Where can I find different size sheet RFA files?
arq_42
Where do people found them working in AutoCAD?
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
jay_colcombe
you need to Insert the Family
Insert Tab > Load Family > Titleblocks
alternatively - Insert Tab > Load Autodesk Family
Then when in the Sheet to change the Paper Size - Select the Titleblock in the Sheet then in the Properties Palette > Type Selector Drop Down
Jay Colcombe
Autodesk Certified Instructor
vitorbortoncello
I will share a file with different sheet sizes.
If you need another size, you can create one from scratch...go to: Families - new - Titleblocks - and edit the lines (width and length)
when done, load it into project:
