Importing IFC from Tekla into Revit
5 ANTWORTEN 5
Nachricht 1 von 6
adimariaBXE2A
208 Aufrufe, 5 Antworten
Hi, I am having issue when importing IFC into Revit: the authoring software for the IFC is Tekla and so containing steel structure components. When I import the IFC into Revit, everything shows as bounding boxes. Did anyone experienced the same? Any solution?
5 ANTWORTEN 5
Nachricht 2 von 6
TripleM-Dev.net
als Antwort auf: adimariaBXE2A
I assume it's displaying correct in a IFC viewer?
What do you mean "import", was the IFC opened in Revit or linked.
I suggest to link it not open, with open Revit will try to generate Revit objects and maybe those boxes are void that exist in the IFC.
Nachricht 3 von 6
adimariaBXE2A
als Antwort auf: TripleM-Dev.net
Hi @TripleM-Dev.net, correct the IFC displays well in IFC viewer, e.g. Naviswork, BIM 360.
The IFC is linked in the Revit file.
Nachricht 4 von 6
azad.Nanva
Use Open IFC file ,in your revit file you can control everythings , and save the Revit file and import the link of Revit file.
Nachricht 5 von 6
adimariaBXE2A
als Antwort auf: azad.Nanva
Hi @azad.Nanva thanks for your suggestion, but it did not work. I have opened the IFC, but once the processing was completed, there was not geometry at all converted.
Nachricht 6 von 6
TripleM-Dev.net
Might be a option to look at the source, see if the owner of the IFC can change the export to IFC in Tekla itself? or Experiment with it?
https://www.tekla.com/solutions/design-interoperability/autodesk-revit
Ps. Can you share the IFC?
