Revit 3D PDF Convertor
arshad.k
Message 1 of 9
arshad.k
Hello Everyone!!
         Can Anybody suggest to me the Best 3D PDF Converter in Revit For Commercial Use.
Thanks, And Regards
Arshad. K
Accepted solutions (3)
Replies (8)
Message 2 of 9
RDAOU
@arshad.k
I have tried several but have been using SimLab's 3D PDF composer for the past couple of years and can recommend it...I think they have a trial version you can check it out SimLab Technologies - 3D PDF (simlab-soft.com)
Message 3 of 9
ahjorn
Yes Simlab 3D PDF is great, I believe you get a 21 day trial.
Message 4 of 9
ahjorn
You may also want to try Bluebeam Revu, you get a 30 day trial and you get splendid results.
https://www.bluebeam.com/solutions/revu
Message 5 of 9
meilechTPVL4
Bluebeam worked Great until I upgraded to 2023
anything available today?
Message 6 of 9
elmarie_barnard
Observer
Observer
Thank you, this was very helpful, does SimLab work on Revit 2024?
Message 7 of 9
elmarie_barnard
Observer
Observer
May I ask what are you using now to convert to 3D PDF? I am using Revit 2023 and 2024.
Thank you so much for taking the time to help, much appriciated
Message 8 of 9
meilechTPVL4
what i have done more recently is export to AutoCad as a DWG and using the Bluebeam Revu plugin on Auto CAD to export as 3D PDF
Message 9 of 9
mohamedsalaah005
Community Visitor
Community Visitor
IN BLUEBEAM I FACED ALOT OF PROBLEMS WHILE EXPORTING 3D PDF CAN U HELP WITH THAT NOT EVERY THING IS EXPORTED IN THE SAME FILTER OR VIEW I WANT AND SOMETIMES IT REMOVES FITTINGS WITH NO NEED OR HIDE, LINKS ARE NOT SHOWN IN THE REAL FILTER I AM LINKING WITH FROM HTE ORIGINAL MODEL.
