Decals
Decals
Decals
I am working in Revit LT 2022 and I can't find the insert decal button. Is it not an option anymore???
RDAOU
@Anonymous
I haven't used Revit LT since version 2017...but I believe that it has been always the case the insert Decals is  not available in Revit LT
Thank you so much! Do you know if there is a way I can insert logos somehow in Revit LT?
Thanks!
RDAOU
@Anonymous
I am not sure what you are using that logo for but you can import raster images to use as backgrounds or visual representations in 2D views or Title block (not Decals which can apply for rendering purposes though)...check under the following:
  • Insert tab >>> Import panel or Link Panel >>> Import/Link Image
  • Manage tab >>> Manage Project >> Manage Images
In Revit LT you can create a material in lieu of a decal.
allanvanessen
How do you scale the image nicely then?
allanvanessen
Nevermind. Got it!
