Revit 3D PDF Convertor
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
arshad.k
803 Aufrufe, 7 Antworten
Hello Everyone!!
         Can Anybody suggest to me the Best 3D PDF Converter in Revit For Commercial Use.
Thanks, And Regards
Arshad. K
7 ANTWORTEN 7
Nachricht 2 von 8
RDAOU
als Antwort auf: arshad.k
@arshad.k
I have tried several but have been using SimLab's 3D PDF composer for the past couple of years and can recommend it...I think they have a trial version you can check it out SimLab Technologies - 3D PDF (simlab-soft.com)
Nachricht 3 von 8
ahjorn
als Antwort auf: RDAOU
Yes Simlab 3D PDF is great, I believe you get a 21 day trial.
Nachricht 4 von 8
ahjorn
You may also want to try Bluebeam Revu, you get a 30 day trial and you get splendid results.
https://www.bluebeam.com/solutions/revu
Nachricht 5 von 8
meilechTPVL4
als Antwort auf: ahjorn
Bluebeam worked Great until I upgraded to 2023
anything available today?
Nachricht 6 von 8
elmarie_barnard
Thank you, this was very helpful, does SimLab work on Revit 2024?
Nachricht 7 von 8
elmarie_barnard
als Antwort auf: meilechTPVL4
May I ask what are you using now to convert to 3D PDF? I am using Revit 2023 and 2024.
Thank you so much for taking the time to help, much appriciated
Nachricht 8 von 8
meilechTPVL4
what i have done more recently is export to AutoCad as a DWG and using the Bluebeam Revu plugin on Auto CAD to export as 3D PDF
