Export to DWG
Export to DWG
qays3PD84
Export to DWG
qays3PD84
I am exporting a Revit file in to a DWG file but the client is asking for below:
The DWG file you submitted is not in a Stateplane Zone 2 NAD83 Feet projected coordinate system (and it needs to be) and the metadata was missing (so that needs to be provided)
Any help? thanks in advance.
L.Maas
Apparently you positioned your project at the wrong location. So you should correct this (in Revit tor Autocad).
Further you did not include some data with the file.
I would assume that other party has document(s) with requirements for CAD files to be delivered, where these kind of things are described. If you do not have those documents, you should contact them to give them to you or otherwise you should talk to them
Louis
Please mention Revit version, especially when uploading Revit files.
andre.micka
You should import coordinates from a dwg created with civil 3d to acquire theses
