Revit 3D Model Disappearing
I am having issues rotating my 3D revit model.
When I rotate it the whole thing disappears from the screen.
I have used the Visibility and Graphics table to check there isn't any extra drawings hidden within the drawing that would make it disappear?
Any suggestions?
Cancel, the problem seems to have sorted itself!
Select an element in your model, hold Shift + press mouse wheel to orbit. If it works then you have something far away from the model.
Viveka_CD
Hi @Anonymous
Glad to know that the problem got fixed. Smiley Happy I marked @ToanDN post as the accepted solution, primarily to benefit other users.
Also a similar discussion HERE for other users seeking similar solutions.
jlcastilloK269F
Community Visitor
Community Visitor
That didn't fix the problem. There are times that you can't select an object in a Revit Link. Rotating the BX 3D view around causes some objects in the Link to disappear and reappear. I suppose the Autodesk hasn't quite mastered the way the lights and shadows  bounce off the objects surfaces 100% of the time while rotating the view. And we pay so much for using the software only for it to perform so poorly
