I'm placing lighting fixtures in a ceiling plan view.
There is no Placement panel in modify tab, how can I display it?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Alan.johnson1970. Gehe zur Lösung
Without checking the actual family
The light fittings look different in the two images, looks like the second one is ceiling hosted.
Will only go in a ceiling, so no need for the placement options.
I was watching a video tutorial , the second image was captured from the video.. and I have loaded the same family that mentioned in the video.. I don't know why there is a difference between the two light fixtures' icons in the type selector list.
I've deleted the family and reloaded it from MEP folder, you are right ToanDN.
Thank you all !
@Anonymous
Please mark @Alan.johnson1970 reply as a solution. He was giving the first correct answer. Thanks!
