Revit 2025 can't export datasmith file?
Kristoffer_Webyte
Message 1 of 15
Kristoffer_Webyte
When I try to export a datasmith file I get error message "Twinmotion is not installed" and a link where to install Twinmotion. However I don't use Twinmotion and I don't want to install a 30GB program just to export a file to unreal.
Replies (14)
Message 2 of 15
eizinmyat
Could you check what version of Datasmith Exporter plugin you have currently installed? I think it is because of the version. I hope it helps you.
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
Message 3 of 15
handjonathan
Hi @Kristoffer_Webyte
Thanks a lot for posting your question to the forums!   Can you check the version as per @eizinmyat suggestion?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 4 of 15
GaryOrrMBI
1) How do you get to that dialog box?
2) What do the addin exporters for Revit 2023 and earlier have to do with the built-in exporter in Revit 2025?
3) The OP is referring to this:
which, according to the help file (which still says Revit 2024 everywhere BTW), requires the installation of Twinmotion prior to being able to use any of the commands under the TwinMotion pulldown
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 5 of 15
Kristoffer_Webyte
1. On the twinmotion tab, which is also there in revit 2024, in which I have not installed twinmotion.
2. Nothing, because I'm talking about revit 2024 vs revit 2025. Because it's literally the same plugin.
3. Yes.
4. I caved and installed twinmotion so I could use this 0.05% functionality of it.
Message 6 of 15
GaryOrrMBI
@Kristoffer_Webyte ,
My post wasn't in reply to your original post but intended to ask @handjonathan and @eizinmyat how and why their replies related to your post.
-G
Gary J. Orr
Message 7 of 15
Kristoffer_Webyte
Oh alright sorry for misreading you. And thank you for understanding what I'm asking about lol
Message 8 of 15
kunze50
I've come across this with Revit 2025 as well. Revit 2024 did not have this issue. It is sad how having Twinmotion installed to export a Datasmith file is now required. For those who want to simply export the file without rendering in Twinmotion or bring into Unreal Engine, this is very unnecessary and a waste of storage. An alternative Datasmith export option should at lease be an option somewhere else within Revit that is unrelated to Twinmotion.
Message 9 of 15
Rab_i
I wouldn't want to install Twinmotion when my workflows are for Unreal engine itself.  Unbelievable!
Message 10 of 15
lucas.ngs
Community Visitor
Community Visitor
So, in the end, we can't export datasmith file on Revit 2025 without downloading Twinmotion!?...
Message 11 of 15
lisemarine_moreira
Observer
Observer
Bonjour j'ai une question au sujet de twinmotion aussi.
J'ai un fichier revit 2025 et j'aimerais le visualiser dans twinmotion.
Je l'ai fait pour mon premier projet et cela à très bien fonctionné. Mais là pour mon deuxième projet cela ne fonctionne plus. J'ai le dernier twinmotion et ai télécharger le Twinmotion 2024.1 for Revit.
Lorsque je fais exporter vers twinmotion ça n'affiche rien dans twinmotion . Alors je fais "Importer" mais dans "direct link" je ne peut rien sélectionner et c'est écrit "aucune source disponible".
Pour ce qui est de mon ancien fichier que je veux synchroniser c'est pareil je ne peux pas et j'ai ça qui s'affiche.
Je ne comprends pas et c'est urgent quelqu'un peu m'aider?
Message 12 of 15
lisemarine_moreira
Observer
Observer
Mais normalement on n'a pas besoin de UE si on a la dernbière version TwinM et Revit.
Message 13 of 15
lisemarine_moreira
Observer
Observer
ais qu'est-ce que je dois faire exactement?
Message 14 of 15
amine_nemer_03
Community Visitor
Community Visitor
Je préfère Unreal Engine à Twinmotion à cause des graphismes, et ce n'est pas parce que vous utilisez Twinmotion que nous devons tous l'utiliser !
Message 15 of 15
esmuch
Observer
Observer
I cant quite understand the reason for this? like each version of Revit , the plugins are less adaptative and less usable. How is is it that something so simple got so complicated. So Many real issues to attend ( Like schedules operability , toposolid , Legends ) and they focus on changing  the things that are working properly, so that you have to install extra stuff to do the same you used to do i one click ... So actually with each update the software is becoming less usable and more irritating for the user.... I am glad they are confident that no other software can beat them.
