Curtain Wall Door Legend
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
Kev_D
2885 Aufrufe, 8 Antworten
Unfortunately Curtain Wall Doors can't be placed in Door Legends like regular Doors can. Understandable, since the dimensions are controlled by the grid lines of the Curtain Walls. So, I was looking to see anyone had a neat workaround. I have done some searches but only found old posts. nothing substantial.
We will probably end up doing the elevation of the Curtain Wall and switching off everything apart from the Door, but that just creates more unnecessary views and it would be great if we could add them to a legend which is much tidier.
8 ANTWORTEN 8
Nachricht 2 von 9
PhilvK
als Antwort auf: Kev_D
Are you saying your doors that our in a curtain system don't appear in your door schedule? I've had no issues with my doors being scheduled.
Nachricht 3 von 9
Kev_D
als Antwort auf: PhilvK
No, I certainly did not mention Schedules. They don't show properly in a Legend View.
Nachricht 4 von 9
martijn_pater
Maybe you can use assembly views...? Not sure if that's the way to go for that...
Nachricht 5 von 9
PhilvK
OK, and yes, that's a pain to try a find accurate workarounds. I usually do what you described. Sorry I misread your post.
Nachricht 6 von 9
I created a shared non host door panel family that can be nested into curtain wall door families and regular door family so that I can pull it onto a legend.
You can also create Assembly and Assembly views from any curtain wall components (doors, windows, panels, lullions) and use them for legends.
Nachricht 7 von 9
Kev_D
als Antwort auf: ToanDN
@ToanDN @martijn_pater
Thanks to both for this workaround. This seems like the best option, however, I would just like to clarify. Can the Assembly be dropped onto a Legend View, or is it just dropped onto a Sheet instead? I can't seem to load it into a Legend View. Am I missing something?
Nachricht 8 von 9
Assemblies cannot place in a legend view.
After create an Assembly you have the option of creating dedicated Assembly views that only show the Assembly components and nothing else. You can place those views on sheet.
Nachricht 9 von 9
Kev_D
@ToanDN
Yes I realize that now. Maybe I should have done more work on it before the last reply. Sometimes I am trigger happy.
Appreciate the help as always. :daumen_hoch:
