Hello everyone!
I have been trying to create a toposolid from a CAD file in Revit 2024, but everytime the toposolid don't match the points from the CAD file. This CAD file is a very precise topografic curve, very rich when it comes to points.
Other problem I noticed is that the toposolid, when created with a CAD file, does not creat nearly as many points as there are in the CAD file.
Here are some prints demonstrating the problem
Did you restrict the toposolid to only reference the contour labels? Also the contours don't seem to be at the correct elevation in CAD, they are all using negative values and the file's unit setting is millimeter.
I think you should first clean your autocad file , i try to clean it and do some fixing but i don't have the enough information .but the data in my opinion is not correct.
the green and red linen have same height and can not been correct.
that what can i do,in this case.
