Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
First time using the new tools - is there a reason why the contour points created from the Toposolid don't match the points generating the Toposolid? In the attached screenshots, the red lines are the contour lines from the civil engineer, which are relatively accurately followed by the points, but the resultant contour lines are way off, even though I can use spot elevations/contour labels to confirm that the actual geometry matches the points properly.
Am I doing something wrong, or is this now how they are expected to work?
Thanks in advance!
