Does anyone have an idea why contour lines are not showing on the attached model using toposolid in revit 2024? I've adjusted the contour display the same way I would do in Revit 2023 toposurface and still they are not shown.
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
These highlighted numbers indicate a vertical range in which the contour lines are displayed. You had those numbers too low. I changed the numbers so that the toposolid is within that range, and now the contour lines display.
Alfredo thank you so much.
I had been entering countour range values based on the "project base point" instead of "internal point". That is I was using 130' stop value instead of 1300'.
The advise was on time before I went bald from scratching my head for days.
Revit 2024 link topography is bringing a published civil 3d surface into the wrong location. It is off by only a couple feet. The project is in US Survey feet. Also the Surface looks terrible when compared to the civil 3d surface. It is not close. This was an old bug in the software that was fixed when using Civil 3d 2023 and Revit 2023 and now it is back in the 2024 Civil 3d, Revit 2024 package.
To fix this I had to multiply my control point northing and easting by 1.000002000004000008000016000032 and convert adjust form us survey foot to international survey foot. After doing this you also need adjust your referenced DWG files as well. Can some one at autodesk fix this glitch?
Also If I upload the toposurface in Revit 2023 the toposurface looks just like the Civil 3d surface. Revit 2024 went backwards in this conversion process.
