Revit 2024: Label in view port
AR.KRISHMA2017
AR.KRISHMA2017
I changed the view port scale to 1/4" and my label came so small in the view port... Can we change the size of the label without changing in other viewport....... Till now its changing in another view port also if i change in one...
What about creating/using a differently sized label?
...this begs the question: Why is the label not annotative? Can you post it here?
Annotations are the same size on 'paper', meaning if you place views of different scales on a sheet, the labels are the exact same size.
