Formula parameters question
mzmaso90
Message 1 of 8
mzmaso90
Hello Guys, Is there a parameter, set-up within Revit, that establish if a specific room reach the air-lighting requirements mad by the: (Area of glass windows/ total steppable Surface of the room itself?
I need also to set an IF formula with a visibility sintax. Is it possible to have a formula that says: IF (parameter visibility1=YES;parameter visibility2=NO)? And when typing this formula in the visibility script syntax, you can avoid to repeat the parameter of visibility2=NO and just type:NO?
Thank you so much for your time,
Best Regards
Lorenzo
Replies (7)
Message 2 of 8
You can't evaluate a Text Parmeter in a formula, but you can evaluate a visibility or numeric Parameter and return Text.
Example:
=if([Visibility Parameter],"Yes", "No")
=if([Integer Parameter]<5,"Yes", "No")
Message 3 of 8
wait a minute. Is this what you are after?
Message 4 of 8
Alfredo_Medina
Oh, no, not again...
1 < 2, 1 > 2
just...
not(V)
Message 5 of 8
huh?
Oh, I get it. OP wants a Visibility Parameter automatically marked the same as another.
Message 6 of 8
Alfredo_Medina
@barthbradley
I am referring to the screen capture in your previous post.
Message 7 of 8
@Alfredo_Medina wrote:
@barthbradley
I'm paid by keystrokes. 😉
Message 8 of 8
And (if (param1, not (param2)))
