Message 1 of 8
Formula parameters question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Guys, Is there a parameter, set-up within Revit, that establish if a specific room reach the air-lighting requirements mad by the: (Area of glass windows/ total steppable Surface of the room itself?
I need also to set an IF formula with a visibility sintax. Is it possible to have a formula that says: IF (parameter visibility1=YES;parameter visibility2=NO)? And when typing this formula in the visibility script syntax, you can avoid to repeat the parameter of visibility2=NO and just type:NO?
Thank you so much for your time,
Best Regards
Lorenzo
