Formula Queries. (visibility with IF settings and Air-lighting autosetting parameter for space)
mzmaso90
mzmaso90
Hello Guys,
1-Is there a parameter, set-up within Revit, that establish if a specific room reach the air-lighting requirements mad by the: (Area of glass windows/ total steppable Surface of the room itself?
2-I need to set an IF formula with a visibility sintax. Is it possible to have a formula that says: IF (parameter visibility1=YES;parameter visibility2=NO)? And when typing this formula in the visibility script syntax, you can avoid to repeat the parameter of visibility2=NO and just type:NO?
Thank you so much for your time,
Best regards
Lorenzo
MetalFingerz
Hi @mzmaso90 ,
Regarding your questions :
1. I do not think so but you can always create your own shared parameter that would follow that formula if you need
2. If I understand right, you have two visibility parameters and the second one is the opposite of the first one ?
If so, then you would need to have a simple formula for Visibility2 that would be not(Visibility1)
