I do a lot of model setups, which typically include up to 5 linked projects for a project model.
Started working in Revit 2024 recently, and I keep running into "Linked file cannot be loaded because it is loaded into another open document" This happens even after I closed the only project file I had open at the time. Revit seems to keep the linked files active after the project is closed. I can go into transfer project standards and see the last 15 or so linked models I had been working with prior, even though none of them are open or linked to the project I'm working on.
The only thing I can do is close Revit completely and start it up again each time I want to open another project file. It feels like such a waste of time. I suppose one of my add-ons could be the culprit, but before I call IT in to start testing them, I wanted to see if anyone else is having this problem?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Closed project, but links are still active]
